I am trying to connect a Concox ultrasonic sensor model USFSCX via RS232 with FMC125, but I have not been able to do it, could you help me do it?
I have already selected TCP/UDP ASCII mode, but I am not receiving any data regarding the sensor on the server.
Maryam
March 25, 2025, 7:00am
2
Good Day
You need to check if the wiring you connected is correct
RX to TX
TX to RX
Ground to Ground
Since TCP ASCII and Binary use code 12, it’s possible that it’s not implemented on the server, which may be why you’re not receiving data? Please check the protocol details from the following link FMC125 Testing RS-232 and RS-485 TCP link mode - Teltonika Telematics Wiki
Alternatively, by using codec 8, you can select the delimiter under RS232 mode. In this case, the data will be received over AVL ID 109 on the server, just like other data and AVL IDs
Please download the latest configurator and firmware from the link and use them during the test Firmware versions - Teltonika Telematics Wiki
Regards
Maryam
system
Closed
May 22, 2025, 8:19am
4
