does the FMC003 work without the SIM inserted?
If so, does the device save the data to be sent when it has a SIM again?
The device is configured, so there no need for receiving SMS. It just have to be about one week without a SIM.
Yes, FMC003 will work even without the SIM but if you need the OEM parameter the device should be connected to FOTAWEB in order to download that.
Once the device is connected to network all of the save records will be sent to your server.
Best Regards
Maynard C
Thanks for your reply. I just realized, that there is no “Store and Forward” mode and that new versions of TCT seem to be not compatible with the FMC003. So I have to test, if that works for me (I use Traccar).
Old version of TCT supports FMB device but the new TCT doesn’t support FMB only FTC devices,
Best Regards
Maynard C
