FMC003 triggers factory alarm on BMW iX1 (2025) – Any solution?
Hi everyone,
I’m using a Teltonika FMC003 (firmware 04.02 Rev.602) in a 2025 BMW iX1.
I’m having a problem with the vehicle’s factory alarm being triggered when OBD communication is enabled. This typically happens around 30 seconds after locking the car, but it has also occurred after a charging session ends.
I’ve tried several OBD configurations, but so far I haven’t found a working solution:
  • With certain settings, the factory alarm is triggered.
  • With other settings, the alarm stays quiet, but no OBD data is retrieved.
My suspicion is that the FMC003 may be communicating with the vehicle while it is trying to enter sleep mode.
Has anyone experienced a similar issue with the BMW iX1 or other recent BMW models?
Is there a way to prevent OBD communication when the vehicle is parked or locked, while still allowing OBD data to be read during driving?
Any advice or recommended FMC003 settings would be greatly appreciated.
Thanks in advance!
Good day,
Thank you for your question.
Please do try below configuration on your device:
  1. Change the ignition source to accelerometer.
  2. Change the Movement Start Delay to 5 Seconds
  3. Change the Movement Stop Delay to 30 Seconds. If alarm still sounding, try to lower it down to 5 seconds.
Please let me know if above configuration fix. Do reach out to us on Helpdesk if issue still persist.
Muaz Z.
Good day,
Thank you for the update.
I have checked the suggested configuration. I am already using these exact settings on my device. I have also tried lowering the Movement Stop Delay to 5 seconds, but unfortunately, the alarm is still sounding.
Additionally, I have deactivated all OBD queries except for io389 (Total Mileage).
Since the issue persists, could you please let me know where I can find and contact the Helpdesk? If needed, I can also provide you with the device’s configuration file.
Best regards
Good day,
If you purchase the device from us, you may contact us via the Partner Portal. Our representative will be available to assist you accordingly. You may further contact your Teltonika Sales manager for further assistance regarding this.
Muaz Z.
Thank you for the information.
I did not purchase the initial devices (which are also FMB140 models) directly from you. However, we are planning to deploy approximately 100 trackers in our operations in the near future.
Given the scale of this project, would it be possible for us to obtain access to the support portal at this stage, so that we can resolve technical issues like this one efficiently and directly? I would be happy to provide the configuration file of the current device for your analysis in advance.
Good day,
Thank you for your response.
Via Helpdesk Query in Partner Portal, we can help and provide more deep technical assistance which involving requesting device logs and further testing.
Please reach out to us from there. You may further contact our Sales Manager for this purposes.
Muaz Z.
Good day Mr. Muaz Z.,
Thank you for the response.
As previously mentioned, without your assistance or an invitation from a Sales Manager, I have no technical access to the Partner Portal to open a ticket. Self-registration is restricted for us as an end customer.
I have now also contacted the company from which we purchase your trackers to request support access. However, since we require a timely solution to this issue and the project with the 100 trackers is about to launch, I ask that you either assist us directly here or set up a temporary Helpdesk account for us immediately.
I can provide you with the configuration file (.cfg) and the required device logs as soon as you let me know how to send them.
Good day,
Thank you for your response. To reach out to us, you can fill up below form so our team will then feedback to you.
Muaz Z.
I have re-tested the settings regarding the Movement Start and Movement Stop Delays:
  • Setting 5s (Start) / 30s (Stop): The io389 (Total Mileage) value is received correctly. However, approximately 1 minute after turning off the vehicle, the alarm falsely triggers.
  • Setting 5s (Start) / 5s (Stop): The alarm no longer triggers. However, the io389 value is no longer received at all. I verified this during a long-distance test drive lasting several hours.
There appears to be a conflict between the stop delay and the retrieval of OBD data.
