When I connect to the FMC double three using Bluetooth classic whether it’s connected via my custom app or testing the connection using Bluetooth serial terminal, the Bluetooth connection only remains connected for approximately 3 to 4 minutes and then automatically disconnects
This occurs regardless of whether there’s been any activity on the Bluetooth data transfer between both or if it’s idle
Is it possible to either disable the Bluetooth disconnection or else extend the timeout window significantly
I hope you are doing well. Unfortunately, we do not have any settings related to adding a configured timeout for the device’s Bluetooth connection, however you may utilize the Auto-connect feature on the device.
