FMC003 bootloop after oemreset command
Hi everyone,
My FMC003 has been stuck in a bootloop since
After I sent an “oemreset” command through the platform.
Looking for anyone who has recovered from this.
— What happened —
I sent a custom “oemreset” command. Device responded with
“OBD OEM FSM restarted”, then dropped the connection (close_code 17)
and never reconnected. Has been completely offline since.
— Current symptoms —
Device is on 12V bench power.
Navigation LED pattern (repeating):
  • Fast continuous blinking ~5 seconds
  • Brief off
  • Solid on for a few seconds
  • Back to fast blinking
This matches the “firmware update in progress” pattern from the wiki,
so I think it’s stuck in a bootloader loop.
USB: continuously connects/disconnects on PC — Configurator can’t
hold connection long enough to do anything.
Bluetooth: same behavior.
Tested same setup with another FMC003 — works perfectly fine.
So it’s definitely this unit.
— What I’ve tried —
  • Power cycle (removed 12V, waited several minutes)
  • SMS cpureset — no response at all
  • Teltonika Configurator via USB — detects briefly then drops
— Questions —
  1. Is there a way to catch the USB window fast enough to force
    a firmware flash in Configurator?
  2. Does Teltonika have a bootloader recovery tool for this situation?
  3. Has anyone recovered a FMC003 from this state?
Any help appreciated. Thanks!
@Imran.S Could you support, please?
Hello.
Thank you for the detailed information and for the effort already made in troubleshooting.
Please note that a Helpdesk ticket is required for further assistance with this issue.
Kindly contact your sales manager to log a Helpdesk case. If you do not have an assigned sales manager, please use our official website https://teltonika-gps.com/ and submit a request via the “Contact Us” form for further assistance.
Kind regards.
