FMC 650 Bluetooth and RS485 Connections
I am using the FMC 650 tracking device to provide a solution where I have connected diesel flowmeters on the CAN protocol which is working. However, when I connect a Bluetooth fuel level sens to the device, it does not transmit the io_721 which is the BLE parameter to the server. On the configurator, the FMC 650 pairs perfectly with the sensor. Does anyone have the experience of connecting successfully with BLE FLS and it’s working well?
Secondly I noticed that to connect wired sensors to this device, on the RS 485 line, you will need to use an extra port has somebody successfully done that? I will need insights into it.
Please provide the advertise protocol of the BLE FLS sensor,
there is some specific configuration for each BLE sensor, also, you need to enable the target IO
I have enabled the target I/O and the sensor is Escort BLE. I have paired them successfully with other Teltonika devices, it is just this one which we have issues with.
Please check the preset in the BLE4.0 settings,
if it is correct, then please contact your sales manager, where we need to have the logs to check what is happen there
I contacted my sales manager and he could not help me.
We would like to analyze your issue.
Please contact your sales manager. If you don’t have any contacts with our Sale managers, please contact with them on our official website https://teltonika-gps.com/ and click on the “Contact Us” button. When you will click, please fill the form and submit it.
