FMC 130 Digital Out
Hi, I Have an FMC130, I am trying to get a digital output to come on within a geofenced area, I have tried to set it up with a manual geofence and set the max allowed speed within the geofence to 0. In the features - over speeding menu i have set the Dout on Duration to 5000 and the Dout off Duration to 0
When the unit is moving the digital output comes on for about half a second before turning off again, If the unit is Stationary the digital output stays off.
Is there a way to keep the output on constantly within the geofence including when the unit is stationary?
Thanks Jared
It looks like this could also be setup with a custom scenario using Coordinates ISO6709 as the trigger source, but I cannot work out how to set the trigger points.
Jared
Good day, this feature is available using our polygon firmware( spec142 ) which is available via the helpdesk, please contact your sales regarding this request.
If you don’t have any contacts with our Sales managers, please get in touch with them on our official website https://teltonika-gps.com/ and click the “Contact Us” button. When you click, please fill out the form and submit it.
Note: As a workaround, you can send a command setdigout command from your server to activate/deactivate the DOUT once it reaches the geofence.
Reference: FMB setdigout - Teltonika Telematics Wiki
Best Regards
Maynard C
