I’m facing an intermittent issue with a Teltonika FMC125 device and would appreciate any guidance.
Issue description:
The device sometimes sends incorrect AVL data, including:
Wrong timestamp
Wrong GPS location
The reported GPS location is not random; it appears to be a location from several hours earlier (old/stale data), sometimes kilometers away from the current position.
When I send the
deleterecordscommand to the device:-
Both timestamp and GPS location immediately become correct
This confirms that the device was sending old stored AVL records instead of real-time GNSS data
Additional details:
This issue occurs periodically, approximately every 15–20 hours
Between these events, the device works normally
GNSS signal conditions are good when the issue happens
No power loss is observed before the problem occurs
Has anyone experienced a similar issue with FMC125 or other Teltonika devices?
Could this be related to:
AVL record buffering or memory handling
GNSS data not refreshing correctly
Firmware-related issues
RTC / GNSS time synchronization
Internal record queue not being cleared properly
Any advice, similar experiences, or recommended troubleshooting steps would be highly appreciated.
Thank you in advance.
