I’m starting up the device after several months of server unavailability.
Regardless of the “Data Acquisition” and “Open Link Timeout” settings, the upload of old saved records to the server is very slow: one data packet in 2-4 minutes
I also tried upgrading the firmware to the latest version - no change
Resetting the configuration and set only basic settings did not help
The device should sends data based on the time configured in the Data Acquisition and the set I/O priority settings.
It also depends on the GPRS connectivity of the sim card inserted in the device, as slow network connectivity can cause the device to close the session and restart it. This can make data sending delay,
For this, check the difference in data and server time stamps.
You can cross-check the issue by adding the device to any other third-party server and verifying if the issue is not coming from the server side.
If you have doubt the issue is from device’s configuration then share the screenshot of the Data Acquisition setting, Record setting, and System setting here,
I will check and confirm
You can disable sleep mode in the device’s configuration during testing.
As this a battery saving mode and has specific conditions to exit and send periodic data when enabled, check the link for details FMC130 Sleep modes - Wiki Knowledge Base | Teltonika GPS
It was just a suggestion for internal testing to disable sleep mode to prevent it from entering ultra deep sleep,
And this is not for delayed data processing.
Hi Maryam,
back to the first question - is there any way to speed up the saved records upload?
One data packet per minute in my case means waiting several weeks to finish process.
To investigate this issue, please contact your sales manager or create an HD ticket.
If you do not have an existing contact with one of our sales managers, you can reach out to them via our official website at https://teltonika-gps.com/. Click on the “Contact Us” button, complete the form, and submit it.
Please create a HD ticket for technical support or contact your sales manager
If you don’t have any contacts with our Sale managers, please contact with them on our official website https://teltonika-iot-group.com/ and click on “Contact Us” button. When you will click, please fill the form and submit it.
