FMB920 not receiving SMS / not attaching to network (1NCE SIM, APN sensor.net)
hey all,
trying to configure my fmb920 remotely via sms but device never seems to attach or receive anything.
setup:
  • sim: 1NCE IoT SIM (apn = sensor.net, confirmed by 1NCE)
  • power: 12v battery
  • gsm + gps antennas connected
  • sms only delivers when sim is in my phone — once i insert the sim into device, all messages stay pending in 1NCE portal
what i’ve already done:
  • sent setparam 2001:sensor.net;2002:;2003:;2004:ch1300513.flespi.gw;2005:32877;2006:0
  • power cycled multiple times
  • verified sim works fine in a phone (data + sms ok)
what’s odd:
  • bluetooth pairing works fine on my Mac (device is visible and connectable)
  • but Configurator doesn’t detect the tracker over bluetooth or usb
  • tried multiple data cables and adapters, still not showing in Device Manager or Configurator
  • enabled roaming
  • set correct apn + tcp server via sms
  • saved config manually
  • rebooted device
still, gsm led keeps fast-blinking → looks like it never registers to any network.
anyone used 1NCE sims successfully with fmb920?
could this be a firmware / radio band / roaming issue?
and does usb failure usually point to a hardware or driver problem?
thanks in advance
Use a Windows device to configure your tracker with the correct APN settings. Mac is unreliable with basically any enterprise hardware you connect to it.
After you configured your tracker and restarted it, look at the status page and check if GPRS shows as enabled and check if data is being sent to your tracking server.
Are you using the latest firmware on your tracker?
Are you using the correct version of Configurator that fits to the firmware version? Because of you are using incompatible versions, they may not detect each other and will not connect.
Are you sure you are using the FMB920? Because you are saying you connected GSM+GPS antennas to it. The FMB920 does not have external antennas.
It shouldn’t be any radio band issue, as the FMB920 is sold as a worldwide version which should work in any GSM/2G network.
And just fyi: By June 2028 Germany will turn off the 2G networks entirely and your tracker will no longer function as you have the 2G version.
Hi, I´ve just discovered after fighting for MANY hours that iPhone sometimes trims leading spaces from SMS, principally for long messages. So for example I was not able to configure the server and port all in one line command, but was able to set the port separately. I was able to configure the server only until sending the SMS from an Android device. So if you send a short SMS from iphone it is sent unchanged, but long messages are “optimized” removing excess trailing spaces, and thus failing the default user /pwd (2 spaces) requirement from Teltonika GPS. Wanted to share here and hope this helps !
PS: Does anybody know a tick so that iphone does not trim trailing spaces?
Hello @Lightning
Good day!
For the band questions, kindly query the 1NCE SIMs provider,
the FW is : https://wiki.teltonika-gps.com/view/Special:Redirect/file/FMB.Ver.04.00.00.Rev.13_and_configurator.zip
usb failure >> Due to multiple reasons, it could be the USB cable, USB port, driver, PC, or the device itself
Hi, i too have this issue, but i’m able to offer a reasonable amount of background info.
The 1NCE service uses their platform ONLY for sending and receiving SMS. You cannot send an SMS from a regular mobile device to this SIM. you can only login to the portal and send the message there.
The issue is the Teltonika tracker (i have tried both the FMB920 and the FMB001) DO RECEIVE the SMS but dont parse it correctly. The payload is CORRECT.
I have been able to SMS my devices for years using the payload “user password command”, so for example:
user pass getver
this has worked for years.
When i send this exact command to the Teltonika, it is received (the SMS received count goes up by 1), but it’s ignored.
I can put the same SIM in a phone and send the same message from the 1NCE platform, and the phone shows the exact and correct message. I can also reply and the platform portal shows the reply.
On the Teltonika trackers, the SMS Sent count stays at zero.
to clarify:
SMS messaging has been working for years.
SMS same message now sent from 1NCE platform, which does arrive and in correct format, does not parse and is ignored.
I also sent a setparam to see if the message is actioned but the reply fails… the setparam is not actioned. so the message simply is not being parsed. a message that worked before.
I believe the encoding that 1NCE sends is not being interpreted correctly, even though a phone will read the message correctly. The tracker does not read the plain text correctly.
Happy to be a tester for devs.
Lastly. i am on latest firmware for both FMB920 and also my FMB001.
thanks
Gus
