Hello!
So i’m very sorry if these are basic questions! but I just want to get a bit of assistance. I’ve hunted through the manuals and not finding what I need.
1 - Wiring - At the moment my tracker is wired with the ignition and perm tracker wires connected to a ignition source so the tracker only turns on when ignition is on. Now this is no good now i think back - if the car gets stolen then the tracker is off. If i was to wire correctly is it possible to “wake” the tracker in the event of car theft. Let’s say its put on the back of a wagon etc?
2 - Is there anyway i can set the tracker up to essentially disable the fuel pump via an sms command? i know i could use DOUT1 to a relay and then a fuel pump etc. But i cannot see anything in the config/nor documentation to how would I actually trigger this? more so again if the ignition is off would the tracker acknowledge the command?
Any help appreciated ![]()
