FMB920 and Escort Bluetooth Sensor
Hello Team,
What is the SMS setparam command to pair an Escort Bluetooth Sensor with FMB920 Tracker?
Hi Good day,
It will be easy to configure the sensor via FOTAWEB .
But to send the command you need to send the setparam commands and set it manually .
Here is the syntax: FMB setparam - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Best Regards
Maynard C
This topic was automatically closed after 6 days. New replies are no longer allowed.
