I would like to find out is it possible to configure one FMB920 with analog fuel and calibrate the LLS calibration, can I use the same configuration with calibration across multiple devices of the same type to be fitted in multiple vehicles of the same that original was calibrated and configured?
I hope you are doing well. Yes, you can connect Analog Fuel sensor on FMB920 as it has available Analog Input port from the device.
Calibration takes place from the Platform End, thus you can use the same Configuration which activates the Analog Input 1 parameter on other devices that has the same Fuel capacity.
