we want to buy some FMB910
- Where do we find a java library to parse the GPRS protocol?
- Is it possible to send tracking data in json format to make everything simple?
- Is it possible to send commands for the tracker in JSON to make everything simple?
- Does ist support LTE or GPRS only?
Thank you
Marcel
Good day, please find the details below:
We are using codec 8, codec 8 extended for data sending and codec 12, 13,14 for sending GPRS command if you want to build your own server please visit this link: Help with Server FAQ - Wiki Knowledge Base | Teltonika GPS
We are not using JAVA by default
If you want to use FM platforms check this wiki page: Fleet Management platforms - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Yes this is possible via Azure and AWS
Wiki pages:
AWS IoT Core: Getting Started with AWS IoT Core - Wiki Knowledge Base | Teltonika GPS
Azure IoT Hub : Getting started with Azure IoT hub - Wiki Knowledge Base | Teltonika GPS
Yes please visit the page for the AWS and Azure.
FMB910 supports 2G network if you want to support 4G LTE kindly use FMC920 device.
Here is the product comparison:
Teltonika Telematics (teltonika-gps.com)
Best Regards
Maynard C
