Subject: FMB910 freezes coordinates and reports speed 0 while moving at 2–4 km/h, with Static Navigation (ID 106) disabled
Device model: FMB910 IMEI(s): [IMEI of the tracker that produced the attached log] (second unit showing the same behaviour: 354002394639262) Firmware version: [from getver or Configurator – Status tab] Configurator version: [ ] Configuration file: attached (primesoft_superseeder_config_v3.cfg) Use case: agricultural implement tracking (super seeder). Devices are mounted on the implement and record one position every second while it works at 2–4 km/h. We need every second of position at that speed; the worked area is calculated from the track. Power: device runs from a battery pack inside an enclosure, external power is not wired (external voltage reads 0 in every record). Ignition source is set in the attached config.
Problem
While the implement is working at 2–4 km/h the device holds the last coordinate and reports speed 0 for tens of seconds to several minutes, then jumps to a new coordinate about 10 m away and holds again. Satellite count stays at 13–14 during the holds, so this is not signal loss. The accelerometer values in the same records change strongly every second (the machine is vibrating and moving).
At about 4 km/h and above the device tracks normally, every second.
Example from the attached log (UTC, 10 Oct 2026, field work at ~3 km/h):
06:31:24 29.7975100 72.6564616 speed 0 sats 14 (held since 06:30:xx)
06:31:25 29.7976000 72.6564716 speed 0 sats 14 jump 10 m
06:31:26 … 06:33:04 same coordinate, speed 0, sats 14 (100 s)
06:33:05 29.7975133 72.6564416 speed 0 sats 14 jump 10 m
Over this 75-minute work session (4,611 records):
- 3,524 records (76 %) repeat the previous coordinate exactly with speed 0;
- 74 releases of the hold are jumps of 8–13 m;
- the reported speed, when non-zero, is 1–5 km/h, i.e. the device is in the speed range where the hold happens.
The 10 m step and the behaviour at a fixed speed threshold look like a static-hold / position-pinning function in the GNSS receiver rather than the Teltonika Static Navigation feature.
What we have already done
- Set Static Navigation (ID 106) to 0 in the configuration, applied it, ran
cpureset, and confirmed withgetparam 106that the device returns106:0. The hold still happens. - Verified satellite count (13–14) and that accelerometer data is live during the holds.
- Checked the record timestamps: records are produced every second during the holds, only the coordinate and speed are frozen.
