What is the sms command to immobilize car engine with FMB640
Hi @h.tiemeni
Good day, if you are using DOUT and relay to do the immobilizer you need to use the setdigout command.
If you are using DOUT 1 the command will be
4 DOUTS
activate DOUT 1
setdigout 1???
deactivate DOUT 1
setdigout 0???
From wiki:
*[setdigout](https://wiki.teltonika-gps.com/view/FMB_setdigout) XXXX Y1 Y2 Y3 Y4* Set digital output
1. # – 0; 1 or ? (0 - OFF, 1 – ON or ? – Ignore) for DOUT1
2. # – 0; 1 or ? (0 - OFF, 1 – ON or ? – Ignore) for DOUT2
3. # – 0; 1 or ? (0 - OFF, 1 – ON or ? – Ignore) for DOUT3
4. # – 0; 1 or ? (0 - OFF, 1 – ON or ? – Ignore) for DOUT4
Y1 – timeout value for DOUT1 if needed (in seconds)
Y2 – timeout value for DOUT2 if needed (in seconds)
Y3 – timeout value for DOUT3 if needed (in seconds)
Y4 – timeout value for DOUT4 if needed (in seconds)
If you are using CAN Control you need to make sure that the vehicle supports engine lock and unlock functionality.
SMS/GPRS commands
lvcanblockengine
lvcanunblockengine
Best Regards
Maynard C
Hello Maynard,
Thanks for your reply.
I have tried it and I succeed to block the car with setdigout 1 but when I send command setdigout 0 nothing happen and the car still not starting.
Any explaination about this?
Thanks.
Henri.
To test it please use the configurator and manually trigger the DOUT , also make sure that the commands were sent correct according to the FMB640 settings.
Best Regards
Maynard C
