Hello
I have Teltonika FMB640, which is connected to Carrier Vector 1550
https://wiki.teltonika-gps.com/view/FMB640_Carrier
Connected and configured according to the manual
The manual contains parameters that interest me
For example, Compressor RPM, Work Minutes and so on
But the configurator does not have these parameters
Why?
Maryam
2
Hello @Project
The value for the Carrier vector will be received over the AVL IDs.
As per the screenshot; you have already enabled all the I/O,so now please check the value on the AVL ID.
You can find the AVL ID from the link below
https://wiki.teltonika-gps.com/view/FMB640_Teltonika_Data_Sending_Parameters_ID#Reefer_IO
Regards
Maryam
Hello
Should I check the parameters via readio?
But I still don’t see the parameters I need in the link you sent.
For example, work minutes, electric minutes
Project
4
Where is these parameters?
Maryam
Closed
5
This topic was automatically closed after 10 days. New replies are no longer allowed.
