following the how to I could manage to have the Data (temperature, humidity, magnetism, ) from an EYE sensor in the I/O, visible in the configurator.
But all the data of the sensor inclusive (most interesting) the temperature doesn’t show up on the traccar server.
I assume, the preset for teltonika devices doesn’t support this.
Any suggestions how to fix this would be greatly appreciated.
Ric
Hello @Ulrich.S,
I hope you are doing well. It is possible to see the Data from the Eye Sensor on the Device Configuration such as Temperature, Humidity, and Magnet detection.
Suggesting you follow the instructions for configuring the Eye Sensor with the FMBXX device, you may refer to this link for more information: https://wiki.teltonika-gps.com/view/Configuring_EYE_sensors
I hope this helps.
Patrick
Hello Patrick,
Thanks for your response.
Yes, I see the Data from the Eye Sensor on te Device Configuration I/O in the upper part
and in the programmable I/O section in the lower part.
So the only problem seems to be, that traccar doesn’t decode it.
Ric
Hello @Ulrich.S,
Great! Just ensure that the I/O Parameters priority is set to Low Priority so you can expect it to be received on your tracking platform. Otherwise, check with your platform provider on why the platform does not decode it.
Patrick
