I’ve been looking at trackers and CAN bus data readings for MB Atego 1517 (2005), fitted with an analog tachograph. I found that the FMB140 (ALL-CAN300) worked well however the local 2G network has been taken down. As I’m looking for a replacement, I’ve come across the obvious FMC150 and as I look through the supported vehicle’s list (for FMX150) I see “Atego mk2” but there are a few discrepancies between the supported vehicle file FMB140 and FMC150 that make me want to double check the compatibility, as the FMB140 sheet mentions two CAN lines but the FMX150 mentions only one, since this surrounds the same vehicle a wonder which is correct in the FMX150’s case? In the FMX150’s list there is also no explicit mention of analog tachographs, not that it actually matters, but it does usually confirm that it’s compatible with the 2005 vehicle. Finally I noticed that before there used to be program numbers for configuration is that no longer the case, as I can’t find such a number in FMX150’s list?
In summary, I don’t doubt the compatibility but the amount of CAN lines and the available parameters and so on is something that I need some clarification on.
Thanks in advance,
