FMB140 + iButton
Hello Team,
I have installed FMB140 with driver identification using iButton. I have 2 issues am experiencing,
  • It takes time to read and authenticate the driver, like 2 minutes.
  • Engine turns off immediately after it has authenticated the driver and started successfully.
    Kindly advise what might be the issue.
Dear @Richy,
I hope you are doing well. Are you implementing the Immobilizer scenario from the device? If yes, kindly follow the steps mentioned on our Wiki Page to further assist you on the connection and device configuration.
Immobilizer Wiki: FMC130 Features settings - Teltonika Telematics Wiki
On the other hand, if you were observing some delays from the iButton parameter from the device, you may follow the configuration setting below for testing and let me know if this helps.
Patrick S.
Dear @Patrick_Sangalang,
Thank you, this worked. The issue I had was a delay in reading and authenticating the driver ID.
Richy.
