Hello to all!
I run into the following issue and I hope someone can help me.
I have an FMB130 (FMB130BSXW01) running the latest firmware (03.29.00.Rev.18).
It is connected to a Vgate iCar Pro OBDII dongle and I get readings from all supported sensors.
The numbers are OK, except from the “Short Fuel Trim” (AVL ID 33).
While I would expect values from -100 to 99, I get values in the range of 240s.
Here’s a sample from the readings in GPS Server platform.
The obdinfo output is the following.
Prot:5,VIN:N/A,TM:30,CNT:13,ST:DATA REQUESTING,P1:0xFC3EB011,P2:0x80040001,P3:0xC8008001,P4:0x8000001,MIL:0,DTC:0,ID1,Hdr:86F110,Phy:0
That, according to OBD 2007 Pid Reader, means that both 0x06 and 0x14 are supported.
I also checked the dongle with Torque Pro application and the “Short Fuel Trim” is shown correctly.
Any clue on what I’m missing?
Thank you!
