I have configured the FMB130 and can see the OBD2 data in I/O.
The I/O are set to Low priority but data is not transmitted to server.
All other enabled data on I/O are send.
Carsten
Carsten
Hi Carsten,
Good day, please follow the instruction in this link: How to connect OBD II Bluetooth Dongle to FMB device - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Note: If you were able to connect the OBD dongle with your FMB130 make sure that the Parameters are enabled like the example below:
Best Regards
I did set this already.
I can also see some values in the list.
But I get only this on my server:
avl ID: 239 : 0
avl ID: 240 : 0
avl ID: 21 : 3
avl ID: 200 : 0
avl ID: 69 : 1
avl ID: 181 : 1.2
avl ID: 182 : 0.7
avl ID: 66 : 12.65
avl ID: 9 : 13.451
avl ID: 6 : 10.904
Best Regards
Carsten
if I use SMS command “obdinfo” I get the following:
Prot:7,VIN:ZFA2500000xxxxxxx,TM:150,CNT:16,ST:IDLE,P1:0x98392013,P2:0x8003B001,P3:0x4CD28011,P4:0x61A88143,MIL:0,DTC:0,ID1,Hdr:18DAF110,Phy:0
So, OBD is connected and data are available.
Why do I not get any AVL ID data to m server?
Regards
Carsten
Hi Carsten,
Good day, the configuration seems okay, can you check the raw data and use the Teltonika parser?
Or if you do not have the Teltonika parser you can use flespi to check if the ODB data is coming directly to your server, flespi panel , you can create a free account on this platform.
I used flespi now and get the following:
ain.1 : 13.286
ain.2 : 10.776
ble.1.custom.payload.hex.1 : “3D68915E42933FDEA380F5CC6EC96D”
ble.2.custom.payload.hex.2 :“3B2C108FD6B34682C27EF6CDCF”
channel.id :1170392
engine.ignition.status :false
event.priority.enum :0
external.powersource.voltage :12.463
gnss.state.enum :1
gnss.status :true
gsm.signal.level :40
ident :“350612070750714”
movement.status :false
peer :“18.196.213.123:40561”
position.altitude :30
position.direction :0
position.hdop :0.8
position.latitude :54.433718
position.longitude :10.416317
position.pdop :1.1
position.satellites :11
position.speed :0
position.valid :true
protocol.id :14
server.timestamp :1692948426.974934
sleep.mode.enum :0
timestamp :1692948395
OBD Status shows:
OBD Setup has e.g. Control Module Voltage and Engine Oil Temp enabled
Kindly check again your configuration and make sure that all parameters that you need are set to low or high priority, you should receive the parameters from the OBD dongle in the IO: FMB130 Teltonika Data Sending Parameters ID - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Maynard C.
Hi Maynard,
I changed priority to high and rebooted FMB130.
Now it’s working.
Thanks for your support
Carsten
