FMB130 intergration with EC-19521 keypad
good day all
i have FMB130 tracking unit which i want to add keypad unit to it for immobilization using 1-wire protocol. i have done the connection but when i try to test using the configuration tool it does not read the data from the keypad, how bets can i deal with this situation.
thank you
Hello!
Ensure your FMB130 tracking unit is properly connected to the keypad and running the latest firmware. Double-check the configuration settings for the 1-wire protocol and verify the keypad is receiving adequate power. Test the keypad with another 1-wire device if possible.
how do i check the configuration settings for 1-wire, and again the connection for FMB130 and the keypad is done properly, of you can advice on how to connect see if it will be same as yours
Hello @Tshepang,
I hope you are doing well. We would like to analyze your issue, kindly contact your Sales Manager so that we can coordinate with you directly.
If you don’t have any contacts with our Sale managers, please contact with them on our official website https://teltonika-gps.com/ and click on the “Contact Us” button. When you will click, please fill the form and submit it.
Patrick
