FMB125 & Ruptela FLS PRO fuel level sensor (RS232)
Hello guys, i have just installed FMB125 + Ruptela FLS PRO fuel level sensor and attached it to Port RS232 of the device and LL1 in the configurator, but I am not getting any reading from that port, (-4). Does FMB125 work with this particular sensor by Ruptela? Kindly advice.
Hello Jonas thanks for the response, just to be clear you mean should interchange the TX of FMB125 to and connect to the RX of the Sensor and vice versa? I had connected the FMB125 RX to the sensor RX and the TX to the sensor TX.
Very clear now. I’ll try that and give feedback for the community’s sake.
Thanks Jonas.
Hello Jonas,
I tried this connection and configuration but i still get -4, it’s not reading. It is the FLS by Ruptela.
Please make sure that the mode, baud rate, and parity are selected correctly.
Kindly check the datasheet of the Fuel level sensor that you wanted to integrate with our device.
