FMB122 - can't reach via Configurator
I have an FMB122 with a firmware 3.10. I try to connect with the configurator 1.77.72 but get an error message:
failed to get status transfer protocol feature
Tried different usb-cables. I don’t have any problems with the other FMB122, FMB125 or FMB130.
Might it be a firmware problem? Can I update the firmware somehow else?
Or is there an older configurator I can use?
Thanks!!!
Please install the driver: https://wiki.teltonika-gps.com/images/d/d0/TeltonikaCOMDriver.zip
Check for the device current firmware and download the correct configurator here: Teltonika Configurator versions - Teltonika Telematics Wiki
Best Regards
Imran S
