FMB120 device showing inactive status on fota i have checked all configuration & GSM related things are fine but devices still showing inactive please suggest the solution
Please send the web_connect command to the device as this will force the device to connect to the FOTA web ,
If the device will still show inactive even after sending above command, then please send the following commands:
sdformat
cpureset
Regards
Maryam
AoA. Can you inform me that is it possible for FMB120 device to send JSON data over custom MQTT broker.?
Hello @obaid
I already answered this ,please check FMB120 data sending over mqtt - #5 by Maryam
Regards
Maraym
This topic was automatically closed after 9 days. New replies are no longer allowed.
