Hi, how do i connect drivers id (ibutton) on a engine start stop (push start) vehicle and what type of relay i should use?
I hope you are doing well. In such scenarios, you could still use the same Immobilizer Feature and 5-Pin Automotive relay.
However, it might be challenging for you to check on the Ignition source as this is required to activate the Immobilizer feature, some vehicles require you to press the brake pedal before they can turn ON the vehicle so you can utilize the Brake Pedal voltage to be the Ignition source.
More information about Immobilizer can be found here: FMB120 Features settings - Wiki Knowledge Base | Teltonika GPS
I hope this helps.
Patrick S.
