jure
January 30, 2026, 3:02pm
1
Hi all,
I have a question about some statuses our FMB003 modules send.
What does deviceOffline status mean? When is it sent? Sometimes this is last status I get and I get it live (not a cached status) so I’m confused. If it means device lost connection, how can it be sent?
2026-01-30 15:16:33 INFO: Event id: , time: 2026-01-30 15:16:33, type: deviceOffline, notifications: 0
2026-01-30 15:17:28 INFO: Event id: , time: 2026-01-30 15:17:28, type: deviceOnline, notifications: 0
Good Day,
Could you please clarify the source of this information — whether it is coming from device logs or server logs ?
Based on our observations, these events appear to be server-generated :
When no data packets are received within the configured inactivity/timeout period , the server marks the device as deviceOffline
When the next valid data packet is received , the server marks the device as deviceOnline
AS.
jure
February 3, 2026, 1:26pm
3
Hi AS,
Thank you for answering.
You are right. This log is observed on traccar server. So it’s not recieved from device.
What I was expecting was unplug detection message but I’m not sure if I can get that. I set it to high priority.
For unplug detection, please enable the feature from the Accelerometer Features section.
Set the following parameters:
Priority: High
Detection Mode: Simple (this uses voltage-based detection)
AVL ID: 252
After applying these settings, please test the behavior. If the issue still persists, kindly raise a support ticket for further investigation.
AS
