Hi
I have look at the wiki and tried to google. I fail to find infomation on how to connect DIN1.
Where can I find this information?
Hi
Hello.
We would like to inform you that the FMB001 device does not have a separate DIN1 wire connection like standard wired devices. DIN1 is available through the OBD-II connector pinout on the device.
Please use the following pin mapping:
OBD PIN 1 = DIN1
OBD PIN 4/5 = GND
OBD PIN 16 = Power supply
To activate DIN1 an external voltage/input would need to be applied to OBD PIN 1 relative to GND.
For more detailed information regarding the device pinout and configuration please refer to the official Teltonika Wiki documentation FMB001 First Start - Teltonika Telematics Wiki
Thanks. Pin1 on OBD should be ignition on Mercedes, but I get no Ignition on/off using DIN1 as Ignition source. It would be good if it worked since its an EQV electric car, and battery voltage is high during charging also.
