FMB001 Devices Stuck on “SIM Initializing” – Suspected Modem Fault
I have four FMB001 units from the same batch. Two of them are working correctly, but the other two are permanently stuck on “SIM status: Initializing.”
Troubleshooting already performed:
  • Tested with multiple known-working SIM cards
  • Verified SIMs work in other FMB001 devices
  • Confirmed power supply is stable and identical across devices
  • SIM orientation and contact pressure verified
  • ICCID, operator name, and signal are not detected
  • Device never progresses beyond “Initializing”
Since identical units with the same SIMs and configuration work properly, it appears these two devices may have defective or non-responsive cellular modems.
Please advise next steps
Thank you.
are you running the latest firmware on the two defective devices? If not, try updating. Re-writing the OS may solve filesystem corruption, if there is any.
