Hello I try to recive the data from E9 minew sensor. I need to get only the X Y Z data.
I tried everything, but I can’t get any data, although I can see that the sensor successfully sends packets. Can you help me fill out the table?
0x0201060303E1FF1216E1FFA10364FF00FFE90007AA5CAF3F23AC000000000000000000000000000000000000000000000000000000000000000000000000
What exactly did you try? You’re not very generous with details…
Check the table below and pic one parameter you want and play around with the given info until you extract the correct data. In your case maybe pick X-axis. Fill out the table above. Set offset of 14 to 14. Set data length of 2 to data size 2…
As a free hint: ChatGPT is very good in this stuff! It might also help you to convert hex to 8.8 fixed-point.
