Hello community,
I am managing a relatively large fleet of FMB series devices (2G) and I am experiencing a persistent issue: the devices appear to go completely offline and refuse to reconnect under any circumstances. The only action that eventually triggers a reconnection is sending a getrecord command remotely — however, even then, the device does not come back online immediately; it takes some additional time before the connection is restored. After investigation, I have confirmed that the root cause is the device getting stuck on a mobile cell tower and failing to perform a new cell scan or re-registration on its own.
I understand this is likely related to 2G network availability and cell tower assignment, but unfortunately I cannot replace the devices immediately with the newer FMC family (4G) due to the scale of my fleet and budget constraints.
Could anyone advise on the following?
Are there any GPRS or GSM connection parameters in the FMB configurator (Teltonika Configurator / FOTA) that can help force a cell re-scan or reconnection attempt more frequently?
Is there a recommended Data Protocol Timeout or Server Response Timeout value that helps the device detect a lost connection earlier and trigger a reconnect?
Are there any known workarounds, such as using a scheduled SMS command or a specific operator band lock, that helps in areas with poor or overlapping 2G coverage?
Does sending getrecord physically force the device to re-establish the data connection, or is the reconnection just a coincidence?
Any experience or configuration recommendations from the community would be greatly appreciated. Thank you in advance!
