which configurator to use for the fw version 03.27.10 Rev:00 03.25.05 Rev:70
thank
Hello @tamatech,
I hope you are doing well. You may access the list of available Configurator versions through the link provided below.
Configurator Versions: Teltonika Configurator versions - Teltonika Telematics Wiki
Hope this helps.
Patrick S.
Good day, I tried all the configurators and they all said it is not supported. Can older versions be downloaded?
Hello @tamatech,
Good day! It appears that the device with Firmware 03.27.10 Rev: 00 is using a special version, as the base Firmware is 03.27.10.Rev.02.
On the other hand, older Firmware, such as 03.25.05 Rev:70, could not be fetched, so either you update the device Firmware to a later version or try to use the oldest Configurator.
If all else fails, kindly coordinate with your Sales Manager to assist you further, as we were not sharing any Firmware or Configurator files on the community forum. If you don’t have any contacts with our Sales managers, please contact them on our official website https://teltonika-gps.com/ and click on the “Contact Us” button. When you click, please fill out the form and submit it.
I hope this helps.
Patrick S.
Can I update the FW by command via SMS or otherwise than via the configurator from a PC? I don’t have access to the website where the device is connected because I bought a vehicle where the device was and I want to start it
Hello @tamatech,
I hope you are doing well. We have another option to update through FOTA Web, but you need to have access to it. You may contact one of our Sales Managers if you want to know more about having access on your device.
Patrick
Could someone update the fw for me via FOTA WEB? And what is needed?
