Eye Sensor accelerometre settings
Is it possible to adjust the sensitivity settings on the Eye Sensors re pitch, roll and movement in the accelerometre?
Good Day,
Thank you for your query.
It is not possible to adjust the sensitivity settings for pitch, roll, or movement on the Eye Sensors. The accelerometer parameters are pre-calibrated by the manufacturer to ensure consistent and reliable performance across deployments.
As a result, these sensitivity thresholds cannot be modified from the user side.
Thanks, and best regards,
Imran S.
Thanks for the reply.
We are finding that they may be way too sensitive for real world use on the likes of gates to augment the magnet sensor. We had hoped to use the movement as a kind of tamper alert.
