Eye beacon not run whit ios
Hello, I have a problem with eye beacon and Apple.
I get a message that iBeacon IOS mode does not work. With eyeapp.
Whit android run perfect!
There’s a solution?
Thank you.
Could you please explain the exact issue you are facing?
On iOS, the only difference compared to Android is that the iBeacon ID is not visible while reading the iBeacon parameters. This is not an issue on the Teltonika side; Apple restricts access to this information for security reasons.
However, if you navigate to the settings in the iOS EYE application, you can still read and write the beacon ID without any limitations.
Naveen
