EYE App: Source Available?
I am trying to write a mobile application that detects the EYE (BTSMP1) sensor. So far, I have been unsuccessful. I haven’t been able to find a good example either.
Does Teltonika make the source code for the EYE App available? That would be really useful.
Thanks,
-T
Hello @gamename,
I hope you are doing well. Unfortunately, we are not providing the Eye Application source code.
If you wish to read/detect Eye Sensor from your application, suggesting you to refer on the Eye Sensor communication protocol that can be found from the link mentioned below.
Eye Sensor Wiki: https://wiki.teltonika-gps.com/view/EYE_SENSOR\_/\_BTSMP1#Beacon_and_sensors_data
Hope this helps.
Patrick S.
No, it doesn’t help. I’ve read the table you suggest. It doesn’t help me understand from a code perspective what’s needed to use the product. I hope to deploy thousands of these little devices but cannot get even a prototype working.
Is there no solid code examples somewhere that illustrate how to work with these?
-T
