Hello friends !
Once the Teltonika configurator is set up, what is the best method to extract all device data in real-time?
Hello friends !
Using the Teltonika Configurator status window, you can monitor live data directly from the device.
However, the primary function of the tracker is to send all collected data to a configured server. To achieve this, you need to configure your server details under the GPRS settings.
Once configured, you will be able to view all device data and GPS tracks on the server.
If you do not have your own server, you may use Flespi, which offers up to 10 device connections free of charge.
Naveen
