Hi, I’ve seen some older posts here from February 2026 about issues with wifi connection being blocked on iOS due to issues. Last anwer was that technicians are working on it, but I did not see any related updates. HAs that been fixed yet? When connecting to EVC2 via wifi from iPhone with iOS 27, should that work or the problem still persist?
Thank you for reaching out.
The Wi-Fi connection issue reported by some iOS users earlier this year has been addressed in subsequent firmware and app updates. Connecting directly to an EVC2 charger via its local Wi-Fi access point from an iPhone running iOS 27 should now work as expected.
If you are still experiencing connection issues, please make sure that:
- The charger is running the latest firmware version.
- The latest version of the TeltoCharge app is installed on your iPhone.
- You remain connected to the charger’s Wi-Fi network even if iOS displays a “No Internet Connection” warning.
- You try forgetting the charger’s Wi-Fi network and reconnecting.
If the issue persists, please let us know:
- The charger firmware version
- Your iPhone model
- The TeltoCharge app version
- The exact step where the connection fails
We will be happy to investigate further.
Džiugas-Teltonika
