Escort dlu-ble gps telto module
I would like to use an Escord accessory with dlu-ble and bucket mode. Which Teltonika GS types are compatible with these accessories?
Hi @maulnrzky
Good day, we already support escort sensors, Presets were also available from our configurator
If the preset is unavailable, you need to create your own preset for the sensor.
Please follow the instruction on this wiki page: Making Custom BLE Sensor configuration and preset - Wiki Knowledge Base | Teltonika GPS
Our device supports Bluetooth 4.0/BLE
Check the links below:
  1. Bluetooth4.0 World-leading GPS Trackers For Aftermarket And OEM Applications
  2. Bluetooth4.2 World-leading GPS Trackers For Aftermarket And OEM Applications
  3. Bluetooth 5.0World-leading GPS Trackers For Aftermarket And OEM Applications
Best Regards
Maynard C
hi @Maynard
Thank you for the information. I have an FMC150; does that mean it already supports dlu-ble? Thank you!
Hi @maulnrzky
If the sensor is already in the preset list then yes. if it is not available, you need to create the sensor preset using the instructions I provided.
Best Regards
Maynard C
