Engine Hours command on FMB920
Hi everyone. How do we send a command to record engine hours on the FMB device? We know how to do the vehicle odometer /mileage however cannot seem to find where to do the same for engine hours. We use Wialon software and require this in order for the report to show an opening and closing hour meter
Example of what we currently get on mileage:
Initial Mileage Final Mileage Mileage
43304km 43318km 13.63km
We are needing on hours to reflect:
Initial Hours Final Hours Hours
250hours 260 hours 10hours
however we currently get
0.00 hours 10.00 hours 10hours
Good day, kindly check this link from wialon website: Engine Hours | Wialon Hosting
For Teltnonika device you need to use an OBD device or CAN Adapter in able to get the engine hours or engine worktime. Engine Work hour also depends on the vehicle’s year make and model.
Wiki page: FMB120 CAN adapters - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
To received the Engine Worktime via SMS/GPRS command you need to send readio 45200
To received the proper data make sure that you have install a CAN Adapter check for the parameter ID and send the readio command.
Reference: FMB readio - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Best Regards
Maynard C
