Hi Teltonika team just tested TFT100 and device looks too old technically, as replacement i see FTC305 but i cant understand why GPS L5 was not implemented in this device (FT platform) and as i see adding L5 to device need board replacement, i mean it cannot be fixed by firmware upgrade right? When GPS L5 will be supported? Also bad to see that device lost 1-wire (+5V) power and has 1-wire merged with DIN1 and AIN1 too strange solution. Can i use +5V from test pads near batterry connector or it will harm batterry charging (will i get same result that was on TFT100 with 1-wire power wire? Also DOUT3 really needed on this device it can be merged with DIN1/AIN1.
No live in this forum?
So device has airoha AG335AT inside and L5 turned of in firmware or it is not soldered on board?
Hello
We are using only L1, L5 will be enabled in the future
is there any special request for enabling the L5?
BR
laith
Hello its mean that bord will be changed too? I mean i cant add L5 in future by changing firmware right? For me its too strange this device is for e mobility and must work in city good but it dont have L5 but cheaper model has.
