DOUT1 stuck in scenario
Hi.
The DOUT1 on my TFT100 is stuck in SCENRIO. when I send the command SETDIGOUT 1 command i get the response SCENARIO.
Any ideas how to get back in normal mode? Is there a way to go back to default settings or factory reset?
Auggie
If you want to reset the configuration please click the reset configuration button.
Regards
Maynard C
Hi Maynard.
I tried to reset the configuration as told but no luck. It still says DOUT: SCENARIO.
Does the “Reset configuration” factory reset the device?
Any other ideas?
Regards
Auggie
Hi Auggie,
Can you try to reinstall the firmware?
If it does not solve the issue, Please create an HD ticket or contact your sales manager to check if the device is for RMA.
Regards
Maynard C
Hi Maynard.
I installed the firmware and it didn’t fix the problem. When I look deeper into it I can se that DigitalOut overcurrent is stuck on 1.
Could this have something to do with it? If so what can i do to get it back to 0?
Kind regards
Agustin
Good day, there is a chance that your device is having an issue it may be a hardware issue or you can try to change the firmware of the device (TFT100 Stable firmware - Wiki Knowledge Base | Teltonika GPS ), if the result is still the same better to create an HD ticket or contact your sales manager.
If you don’t have any contacts with our Sale managers, please contact with them on our official website https://teltonika-gps.com/ and click on the “Contact Us” button. When you will click, please fill the form and submit it. Note: as a topic, please choose “Vehicle telematics”. Or you can send an e-mail with description of your situation to us: Teltonika - IoT, Internet of Things When contacting Us, please provide: IMEI/Logs/Configuration file/Intenational GSM number/Firmware version/ect , please follow these recommendations: Recommendations for filling a query description - Wiki Knowledge Base | Teltonika GPS
Best Regards
Maynard C
This topic was automatically closed after 6 days. New replies are no longer allowed.
