Does FMC150 support MQTT? What topic does it use?
Hi, I purchased an FMC150, but I would like to know if it supports MQTT and which broker servers are supported. Also, if the MQTT protocol is supported, what topic does it use for publishing data?
Is there a documentation about FMC150 and MQTT?
Good day, yes FMC150 supports MQTT protocol, the supported brokers are AWS and Azure.
Kindly download the latest firmware here: https://wiki.teltonika-gps.com/view/Special:Redirect/file/File:FMB.Ver.03.28.07.Rev.159_and_configurator_update.zip
Wiki pages:
  1. Getting started with Azure IoT hub - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
  2. FMB120 Getting Started with AWS IoT Core - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Best Regards
Maynard C
