Does FMB001 send io_239 (ignition) and io_36 (rpm) all together?
Hi
Does FMB001 send io_239 (ignition) and io_36 (rpm) all together?, I ask this question because sometimes my Wialon detects ignition is off but rpm > 0, or ignition is on but rpm = 0.
what config should I consider to resolve this?
Hello @Win
Initially, were you able to retrieve the RPM value from the OBD device through the OBD port of the vehicle?
If not, the device might not support retrieving the RPM as the OBD device can only fetch data that is available on OBD port.
About this Question , Does FMB001 send io_239 (ignition) and io_36 (rpm) all together?
Yes, the device can send the values of all AVL IDs to the server, whether the ignition is on or off, depending on the configuration.
Regards
Maryam
This topic was automatically closed after 13 days. New replies are no longer allowed.
