I would like to develop an IoT solution that collects CAN bus data from a vehicle using the CANopen protocol; the FMC could enable me to do this thanks to the ‘CAN manual’. The problem is that I’d like to connect the FMC650 directly to the ThingsBoard cloud without going through an intermediary; this doesn’t seem possible via TCP/UDP, and MQTT connectivity is only supported for AWS and Azure servers.
Has anyone managed to establish a direct connection between ThingsBoard CLOUD and a Teltonika FMXxxx?
Thank you.
