Deep sleep Mode FMM130
I have installed the tracker in a tractor. The tracker is connected directly to the tractor’s battery. My goal is the following:
  • When the tractor is transported on a trailer, the device should report its position during movement even if the ignition is off.
  • When the tractor is parked and no longer moving, the device should return to Deep Sleep mode.
However, in my current configuration, the device does not seem to enter Deep Sleep at all.
Could you please review this behavior and let me know which parameters need to be configured so that Deep Sleep works correctly and the tracker still wakes up and sends position data when movement occurs (e.g., during transport)?
Below you can find the settings I have applied:
Device: FMM130
  • 112: 3
  • 113: 1
  • 2005: 10000
  • 134: 1
  • 136: 1
  • 101: 5
  • 105: 13600
  • 102: 2
  • 138: 2
  • 103: 120
  • 50170: 1
  • 10050: 30
  • 10055: 1
Hello @Northstar,
Good day! Device has criteria before it enters the Sleep Modes, kindly review this link so that you can learn more about the device requirements before going to Sleep.
Patrick
