Data Logging Per Second
I am using the FMC150 device, and I would like to know if it is possible to retrieve per-second log data from the device especially in the event of an incident.
Looking forward to your response.
Could you clarify if you are referring to crash data (like X, Y, Z axis info during the crash) or CAN message data (raw messages during some event)?
I’m referring to detailed positional and speed data logged every second by the FMC150 and stored internally. The idea is to transmit summary data every 1 minute, but keep the full per-second log for retrieval after an incident. This is not limited to crash XYZ axis data or raw CAN messages.
Unfortunately it’s not possible at this moment. Any record device generates/saves is transmitted to the server.
Thank you for your explanation.
I understand the current limitation that every record is directly transmitted to the server.
However, I believe that the ability to log and store high-frequency data (e.g., every 1 second) locally before transmission could be a very valuable feature for many use cases, such as detailed route analysis or offline tracking.
I hope this can be considered for future firmware development.
Hi, the FMC150 device typically logs data at 1-second intervals, especially during incidents if configured correctly. Please ensure high-frequency tracking is enabled in your settings or contact support for assistance with event-based logging. Bible Chat Ai
Thomas Henry
