DashCam RS232 option does not show up
Trying to configure the DashCam with FMC125, using the 1.7.72_B.3.29_R.11 [03.29.00.Rev.18] for configuration, but the DashCam option does not show up in RS232 Modes. The Data Protocol is also set to Codec 8 Extended.
Also tried this version: DashCam Firmware errata - Teltonika Telematics Wiki. But it did not work.
Dear @joaben,
I hope you are doing well. Kindly use the Dashcam Firmware and Configurator so that you would be able to see the Dashcam option through RS232 since it requires a special Firmware for you to be able to configure it.
Firmware: DashCam Firmware errata - Teltonika Telematics Wiki
I hope this helps.
Patrick S.
Thank you, that solved the issue.
