Custom Scenario FMC130
Here is what I have:
FMC130 with Firmware 04.00.00 Rev 121
Teltonica.Configurator 1.8.11.E.CUSTSCEN_R.13
PROBLEM:
I have the feeling that Custom scenarios are not working at all!
SOLUTION:
Do you have a simple setting I could make to test it?
Like => Custom Scenario 1 = High Priority, DOUT 1, Permanent Output Control disabled, Trigger #1 –> Ignition, OnEntrance, High Level 1
Just a simple setting, that I know excactly, if I’m to dumb to use Custom scenarios or if something other ist broken.
Thanks in Advance
I suggest you to read on the Custom Scenario Wiki Page to learn more about the feature of the device. Please refer on this link for more info: Custom Scenarios - Teltonika Telematics Wiki
Patrick S.
