Controlling max allowed from-grid current over OCPP
My DLB smart meter is not currently functional. So i configured my EVC1 manually to use 9A from each phase. It was working as expected. Then I connected the station to Wifi and from there to an HomeAssistant OCPP server. Everything works fine except that at the first charge the station offered 14A on each phase. The app does not offer the configuration area anymore unless i disconnect from OCPP. It says “configured by ocpp”. So where did the 14A come from ? I will try to use chargingSchedule.chargingSchedulePeriod[].limit to limit this in the future. Just wanted to know where those 14A came from ?
thanks
Once the charger is connected to OCPP and accepts charging profiles or current limits from the OCPP backend, the local charging current settings in the Teltonika Energy app are overridden and the app will show “configured by OCPP”.
The 14 A limit was most likely not generated by the charger itself, but was provided by the OCPP backend or derived from the charging profile that was active at the time of charging. It is also possible that the backend applied a default charging limit when the charger was first connected before any custom charging schedules were configured.
We would recommend checking the charging profiles and default current limits configured in your Home Assistant OCPP integration. In particular, the chargingSchedule.chargingSchedulePeriod[].limit parameter is the correct place to define the maximum charging current that should be offered to the vehicle.
Kindest regards,
Džiugas-Teltonika
